Generator Charging System on MD
Posted by JDM on July 23, 2001 at 17:03:03 from (206.74.34.150):
Ok ,on the advice of Bob M Im posting this question that I asked him via email.I have a 41 M,with the generator from a 50 MD,12 volt,3 brush.The junker this came thing off of was pos. ground and was told that was correct so I wired everything up for that.On Bobs diagram for generator wiring,there are two lines which go into the fuse,one for the lights and one for the kill switch.When I wired it up per the diagram i only got 4-6 amps.If I disconnected the L wire from the regulator,shot up around 7-10.I set the brush to get that but wish it would go just a tad more.I then took the wire from the L terminal and hooked it the fuse and moved the ignition wire to the amp gauge.Teh gauge will still read the 7-10 amps.voltage puts out about 13.5-14 depending on rpms.Just tried the lights(I just got them hooked up only a few minutes ago)Turn them on and no change in the gauge,shouldnt there be at least some?OK,now does all of this sound "normal" to you guys?IS there any difference in the wiring that I may have overlooked?(Keep in mind that all wiring is new and was originall wire per Bobs diagram.)Thanks
Post A Followup
: Re: Generator Charging System on MD
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
