Re: Re: Re: Super M tune up
Posted by Bama Binder on August 07, 2001 at 04:49:15 from (63.10.118.15):
In Reply to: Re: Re: Super M tune up posted by Dale(MI) on August 06, 2001 at 19:49:17:
I don't know how much more I can elaborate because I got that out of the shop manual (paraphrased of course). The basic idea is you have 2 timing marks. As the engine rotates, the first mark is for 0 degrees advance (for low idle) and the second mark is at the 16 degree mark (for full RPM). You can set the low idle timing without the engine running by finding TDC of the compression stroke on #1. When you are on the compression stroke on #1, line up the first timing mark with the pointer. This should be 0 degrees of advance. Then take the plug out of #1 and ground it to the block with the ignition on (disconnect the other plug wires so you don't run the risk of the engine starting. Loosen your distributor and rotate it until #1 plug that is grounded fires. Lock down the ditributor there. You will be set for correct timing at low idle. Assuming your advance is correct, when you start the engine and run it up to full RPM and check your timing on #1 against the timing marks, the timing pointer should be hitting on the second mark. The book says that the tractor should really be set so when at full RPM and full advance, the distributor should be adjusted so it is firing exactly on the second mark. Hope this helps...BB
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
