Re: 656 shifting problem
Posted by kev@ia on August 15, 2001 at 18:46:22 from (206.72.15.209):
In Reply to: 656 shifting problem posted by Mark on August 15, 2001 at 06:01:54:
Hello Mark, I know what your talking about, dads 544 uses the same shift setup. I made a new shifter shaft and built up some worn areas so that most of the shifting woes were curred back in Dec or Jan. The Quick fix that will help is to remove the casting that holds down the springs on top of the trany and put a short 1/4 bolt with the threaded portion in the spring and the head against the ball so it is under more preasure. Also make a bigger hole in the shaft that runs through the links so that the ball bearing can make nuteral more evident. Get a over length die makers dowl pin and grind to length as it will bear on unworn metal and remove a lot of slop. The factory pin is to short and wears to fast.
Check the archives as I posted about this before. Good luck and if you need more help just post for it.
kev
Post A Followup
: Re: Re: 656 shifting problem
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
