Farmall Tractors Discussion Board
Re: E4A Mag timing
Posted by C. Fitz on February 28, 1999 at 06:16:27:
In Reply to: E4A Mag timing posted by Farmall Gray on February 25, 1999 at 16:44:34:
I time my F-30 like this. Pull all your plugs out, crank engine until #1 piston is on compression stroke. Fully retard your spark. It is nice if someone can turn engine for you. I physically watch #1 piston with a small flashlight; as the piston is coming up slowly your impulse should trip right at top-dead center.If it does not take your cap off your mag. and see where your dist. segment is; it should look like about 2 o'clock. If your tractor will start its got to be somewhere in the ball-park. I would then disengage your pawl on your impulse and at a very little at a time move your segment re-engage and crank your engine again, watch #1 one on comp. stroke and see where impulse trips this time. Note if your timing got better or worse and just keep repeating this until she's firing at TDC. Ido not trust the marks on the flywheel; I find this to work the best for me and I've done a mess of them. Give me a holler if you have any more problems.
Post a Followup
: Re: Re: E4A Mag timing
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
