Re: Re: Re: Re: Re: Voltage ?
Posted by Les in SC on October 02, 2001 at 02:24:47 from (206.155.220.79):
In Reply to: Re: Re: Re: Re: Voltage ? posted by Stan on October 01, 2001 at 17:26:58:
Stan: You do not have a short, if you had a short you would know it by the burned wire insulation and the smoke. With a bad ground anything is possible. You haven't said if you are using a 6 or 12V system,but in either case all grounds should be clean and tight, a 12V system will just generate more smoke. You haven't said weather or not all light are burning with equal brightness.If one light is dimmer than the others, start your troubleshooting with that light. Your light bulbe gets it's ground inside the light housing and the light housing is grounded to the tractor chassis through the mounting bars. When you open the bulb housing you will see a wire riveted to the housing and soldered to the bulb receptacle, make sure that this wire is making a good ground. At this point you can take a piece of # 16 or larger wire and with the lights on see if there is any change when you place the wire ends to a good ground (ground side of the battery is recommended)and to the light bulb ground. You may have to dismantle the lights and light mounting's, cleaning each till a good ground is made. I will also suggest that you clean all positive voltage connections in the light system as you go along. I hope this helps.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
