Re: Farmall M Front Oil Seal
Posted by EZHangin on October 08, 2001 at 06:35:14 from (216.211.7.80):
In Reply to: Farmall M Front Oil Seal posted by Bud on October 07, 2001 at 17:26:11:
I just did my '44 A.
Jack up the tractor from the center i.e. clutch bell. Make sure you block up the back tires so the tractor doesn't roll. After jacking up , I put some big wood blocks under the clutch bell to hold it up. You have to jack it up enough so that the front tires are off the floor about 2 inches. Remove all the stuff from the front, rad , fan, etc...On the A , I also had to remove the governor as it is mounted on top the timing chain cover. Once you are down to the pulley, I had to pull mine with a bearing splitter as there is no threads on the A shaft end.
****NOTE: You may find that when you order the new shaft seal , it may not fit real tight into the timing cover, I had to use a strong sealant to hold it in. Still not sure why it was out of tolerance about .006
I will actually be installing my timing gear cover and pulley back on today.
Post A Followup
: Re: Re: Farmall M Front Oil Seal
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
