Re: M wobble Need help!!!!!
Posted by john d on October 09, 2001 at 22:24:49 from (205.188.192.43):
In Reply to: M wobble Need help!!!!! posted by Evan on October 09, 2001 at 16:27:50:
Likely not. The wobble can come from several sources, and may be a little bit from each. Check the simple places first (they're also the cheapest and easiest to get to) and remember, every little bit of play removed will help some. First, remove the hood and take it for a drive. Don't forget to watch where you're going, but pay attention to the steering shaft in front of the universal joint at the front of the gas tank. If the front half of this shaft is moving when the steering wheel isn't....that universal and/or the bearing next to it, is shot. Next place to look is the little ball bearing at the very front of the steering box on the top of the front bolster. That bearing is not hard to replace, and if it's worn it will cause all kinds of wobble. While you're at the gearbox, see if the worm and sector gears have been running dry. No oil in there will kill them quickly. Sometimes the sector gear will be a full circle and can be rotated to another place. Don't count on this. Worn or loose front wheel bearings can cause some of your trouble. Run one front tire up on a block of some sort so the other is in mid-air and shake the free one to check for play. Repeat for the other side. The bolster has two bearing surfaces. If the other stuff didn't cure the wobble, these bearings may need replacement. They aren't fun, but they aren't impossible for the average guy to do. Search the achives for tips on how to remove and replace these. If you block up the front of the tractor and you can shake the bolster shaft from side to side or front to back, they're shot. If you replace the front bolster bearings, be absolutely CERTAIN you have the tractor blocked properly, brakes set, leave it in 1st gear and keep any kids away! We don't want to read about you being under the front of that M! Good luck! jd
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
