Well, that depends. The 3788 did not come with dual pto so some one may have taken care of any internal shaft size changes couplings already . One other thing, there are two different dual pto units, early ones have adjustable pressure engagement valve stem that is pulled up for engage with spring loaded brakes when shut off so shaft will not turn with or without engine running. Later one has hydraulic locked engage with valve spool pushed down in to unit, hydraulic shaft brake that is applied when engine is running and pto shut off but shaft is free to turn when engine is not running. Either unit will fit and work but they have opposite operating lever linkage so you need correct linkage for your unit and correct size and length of internal shaft and couplings. .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
