Re: IH Farmall M
Posted by Ray M41 on November 10, 2001 at 17:47:17 from (66.85.182.60):
In Reply to: IH Farmall M posted by george goodwin on November 10, 2001 at 14:06:02:
If you must have it in gear before you start the engine then I assume you are depressing the clutch peddle when you start the engine. You then release the clutch and go. What I think you mean is that you cannot change gears while the engine is running and with the clutch peddle depressed. Was it doing this when you (I assume)drove it before you bought it? Does it have a belly mount hydraulic lift-all? Does it work? Does it have oil? The belly mount lift-all acts as a dampening device to slow down the countershaft gears from spinning so fast and then you can change gears. Those things don't have syncronizers. I'm not sure how the ones with the live hydraulic pump works. Maybe the TA has something to do with it. I did repairs to the belly pump on my M and with the pump off I wanted to take a drive around the pasture. I too had to start it in gear and then drive off. I went on to remove the clutch and check it out while I was up in there. There is no magic to these. Get a owner's manual and check the linkage and fluids. If the previous owner replaced the clutch we might assume he did it correctly and it was working. (I am assuming a lot.) It's possible something came loose or that little coupling to the hydraulic lift-all unit fell out.
Home
| Forums
Today's Featured Article -
Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
