Yes, the ratios are different between the planetary and clutch type IPTOs. In addition, because the 560 ran faster than the four cylinder, that accounts for another speed difference. However, some 560s may have come from the factory with the earlier planetary IPTO.
I have a 660 with a planetary IPTO. Due to 2400 RPM engine speed on that model, it is possible that all 660s used the planetary. Too lazy to look it up and risk a potential brain warp while sorting out all the different parts, IPTOs, and tractors.
Without checking my parts book, there may be as many as four different IPTO driven gear/driving gear gearsets in the clutch/TA housing.
If you need correct 540 RPM, you can only replace same style IPTO with one that is similar in the SMTA thru 660 tractors. Without checking the parts book, one might assume that the couplings are different so that a farmer would not be able to make field changes that would be dangerous.
Do your own research at the CaseIH on-line parts book.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
