Re: A Bob M or anyone else charging ?
Posted by Bob M on November 14, 2001 at 12:24:29 from (165.170.128.66):
In Reply to: A Bob M or anyone else charging ? posted by Paul Shuler on November 14, 2001 at 11:14:21:
Hey Paul - Same thing happened to my Super M while at a tractor show a couple years ago. Problem turned out to be the an intermittant malfunction in the alternator's internal regulator. Replacing the regulator solved the problem. Testing for a failed regulator is simple: Look for a 1/4" dia hole in the alternator end bell. About 1/4" inside this hole find a short metal tab. You bypass the regulator by taking a screwdriver and CAREFULLY inserting it to ground the metal tab to the end bell with the motor running at full RPM. If the alternator charges with the tab grounded, you know the regulator is bad. (If it does not charge with the tab grounded, the problem is elsewhere - bad brushes, failed diodes, open winding, etc) The regulator is easy to replace in place - you don't need to remove the alternator from the engine. First remove the ground cable from the battery. Then take out the three long cap screws the holds the end bell onto the alternator. Now carefully pry end bell off. Inside the end bell you'll find the regulator - the small white plastic device with 4 connections. Simply undo the connections and swap out the bad regulator. Finally reverse the process to reassemble. (Tip: Before you replace the alternator end bell, push both brushes all the way into their holders and temporarily hold them in place with a straightened paperclip inserted in the holes provided in the end bell and brush holders. Then after the end bell is bolted back on, pull out the paper clip out - the brushes will drop onto the slip rings and you'll be set to go). Find a regulator at NAPA, any starter and alternator shop, etc. Last one I bought was about $10. Also it's a "one size fits all" regulator for all Delco 10SI and 15SI alternators. Good luck!! Bob M...
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
