12v on a 6v has anyone tried this?
Posted by Lyall on November 23, 2001 at 21:55:15 from (199.6.154.36):
I found this on a hot rod site. Has anyone tried this to start a stubborn 6v tractor? About a starter turning over good on 6V and not dragging, I suspect the starter is not the problem. Something to consider is the newness of your mill. If it's still a little tight, it takes a lot of voltage to crank it over when hot and clearances are minimal. After a 1000 miles or so, it'll be loosened up and may start up when hot. If the trouble persists, try this to determine where the problem is.... get the engine hot and shut it off. While your waiting for it to heat soak and get hard to start, connect one post from a spare 12V battery directly to the starter post (you don't need to remove the 6V cable). After you're sure it's been long enough and the engine is hard to start, connect the other post of the 12V battery to a ground on the car. This will engage the starter using 12V. Then, the 6V is dedicated to only the ignition system. DO NOT PUSH ON THE 6V STARTER BUTTON WHILE THE 12V IS ENGAGED! If the engine fires right up, you know the starter is pulling too much load from the 6V system and there isn't enough left to fire the ignition properly. These flatheads sometimes get balky when shut down and especially if they're built up with more cubes and compression. Mine does. So I run both a 6V and 12V battery. Everything runs on 6V including the starter. The 12V is also connected to the starter and has it's own starter button up under the dash. If it won't start right up with the 6V, I stop using the 6V button and hit the 12V and it fires right off. The 12V battery doesn't charge from the car's 6V generating system, but is a total loss system. I trickle charge it overnight only twice a year since it doesn't take much to start these engines. Write me if you want to know how to hook up both batteries.... rumble seat
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
