Farmall Tractors Discussion Board
Re: H upper main bearing removal and piston ring installation.
Posted by Greg on March 11, 1999 at 16:11:32:
In Reply to: H upper main bearing removal and piston ring installation. posted by The Red, John Fritz on March 11, 1999 at 06:40:48:
Red, Take a cotterpin, 1\8 in dia. put it in a vice form the top to look like a T, insert it in the main oil hole in the crank , rotate the crank , it will push the upper shell out, to install, oil the shell, start in the cavity push the shell around till it starts to bind, insert the pin, rotate crank till tab is close to its seat, push it in with screwdriver. Good luck
Post a Followup
: Re: Re: H upper main bearing removal and piston ring installation.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
