Re: Can Generator be 6V OR 12V
Posted by Bob M on December 12, 2001 at 11:55:49 from (165.170.128.65):
In Reply to: Can Generator be 6V OR 12V posted by John on December 12, 2001 at 09:59:13:
The starter shop is right - you can't simply stick a generator on a stand and determine the design voltage. However since your tractor has 12 volt lights, chances are pretty good the charging system has been converted 12 volts. Here's how I'd verify: 1 - Get the all the wiring to the generator, voltage reg and ammeter connected correctly. 2 - Drop in and connect a charged 12 volt battery. At this point it doesn't matter which battery post you connect the grounded battery cable to. 3 - Turn on the lights and look at the ammeter - it should show a few amps of discharge. If it shows charge, swap the two cable connections at the battery. 4 - Now polarize the generator (use a short jumper wire to momentarily connect the BAT and GEN terminals at the voltage reg) 5 - Finally start the tractor, run it at 1/2 speed or higher and check the ammeter. If it indicates charge, you're all set! If it does not.... 6 - With the motor running at about 1/2 max RPM, jumper the regulator FLD terminal to a good ground, then jumper the regulator GEN and BAT terminals together. If the ammeter now shows charge, get a new 12 volt regulator. If it still does not charge, you've either got a 6 volt generator or the generator itself is no good. Hope this helps....
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
