Re: Re: Re: Re: Re: Re: Hydraulic Ports On C??
Posted by Clyde on December 13, 2001 at 05:43:37 from (63.146.82.124):
In Reply to: Re: Re: Re: Re: Re: Hydraulic Ports On C?? posted by Haas on December 12, 2001 at 19:21:52:
After thinking about my setup and taking another look at the tractor, gotta admit you're right Haas. Here's how the Saginaw adapter is setup. The return line on the new adapter goes straight thru and has no other connections to it. The pressure side of the adapter doesn't go all the way thru. It is open on the tc block side of the adapter and has a right angle connection for the new open center spool valve. In other words with neither system being used the flow is from the pump via the test hole on the manifold block out to the new center open valve and back to the pressure input hole of the tc block. Instead of parallel the new system is in series with the pressure side of the original system. I was thinking both went straight thru because the gaskets Saginaw supplied were original style with holes for both. As you can see I know just enough about hydraulics to be dangerous.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Hydraulic Ports On C??
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
