Re: Re: Re: Governor Problem Solved !!!
Posted by Bob M on December 17, 2001 at 11:06:07 from (165.170.128.65):
In Reply to: Re: Re: Governor Problem Solved !!! posted by EZHangin on December 17, 2001 at 09:33:45:
EZ - Presuming you've got an internally regulated Delco alternator, the problem might be a bad internal regulator. You can test like this: Look for a 1/4" or so diameter hole on the back end of the alternator. About 1/4" deep inside that hole look for a small metal terminal. Start the motor and run it at full governor. Bypass the regulator by taking a small screwdriver, CAREFULLY inserting it into the opening until it touches the terminal, then while screwdriver tip is still in contact with the terminal, grounding the screwdriver shaft to the alternator case. If the ammeter now shows charge (or voltmeter indicates to 13+ volts) it says the internal regulator is bad. If it still does not charge with the regulator bypassed, the problem's elsewhere in the alternator. Also what the rating of the warning lamp your are using? If the lamp is too small (draws too little current) it will not permit the alternator to "turn on". The lamp should be rated at about 200 milliamps - like a #168 or #192 instrument panel bulb.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
