Re: 300 Util won't start, just click....
Posted by Mark W. on December 17, 2001 at 17:31:46 from (63.168.30.40):
In Reply to: 300 Util won't start, just click.... posted by In the Red with Red on December 15, 2001 at 13:44:52:
At the risk of repeating what the other guys have said, I think I'd try the easiest and cheapest stuff first. 1. Make sure the battery and starter cables are in good shape. In particular, all terminals need to be clean and tight. Don't trust an ohmmeter here - - a poor connection can sometimes conduct plenty enough current to look good to an ohmmeter, but not nearly enough to crank the engine. You should have some good, clean, shiny metal on both ends of every cable (battery +, battery -, and solenoid-to-starter) and on the things the cables connect to (starter post, solenoid posts, and chassis ground). Double check the battery terminals; they can look tight when they're not, and they don't have to be very loose to cause problems. 2. Still no luck? With the tractor OUT OF GEAR, BRAKES SET, and everything else you can think of to immobilize it (distributor cap off might be good too), bypass the solenoid by disconnecting the battery cable at the solenoid and MOMENTARILY touching it to the solenoid end of the starter cable. This passes full battery current directly to the starter motor. Don't be surprised if you get some sparks whether or not the starter growls to life. If it still doesn't work, suspect (A) jammed starter, (B) bad starter, or (C) stuck engine. (You've already said you're sure the battery is good.) If it does work, then: 3. Reinstall the battery cable to the solenoid. Check to be sure the ignition switch is sending voltage to the solenoid when in the "start" position. If it's getting voltage, and you're getting a click, the solenoid is actuating but not passing enough current from the battery cable to the starter cable. I hope this helps. You should be able to follow this path and get some good information without spending too much time and money.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
