Re: M Oil Pump
Posted by Dan on December 26, 2001 at 19:40:10 from (12.18.158.25):
In Reply to: M Oil Pump posted by John on December 26, 2001 at 17:05:10:
If the pump shaft "rattles around" in the pump it has a problem. If you take the bolts out of the bottom cover you will feel spring pressure from the relief valve spring. The pieces in there are large and easy to find but shouldn't have that much pressure when you get to the end of the bolt threads. Once you get the bottom cover off you can check for clearence between gears and the case, it is supposed to be between .004 to .006. If the drive gear moves sideways, probably the shaft is worn at the outer end or the housing. In that case you are better off to look for another pump as the shaft and gear(sold as a unit by IH) run $250 from them. Shaft could be made by a machine shop and gears pressed on the gears afe keyed and have a role pin in them and are press fit. There are gaskets between the bottom cover and pump body. Clearence between the gears and bottom cover should be 3-5 thousands. You can use plastigage to measure this. If you have more than one gasket on the bottom cover you can remove gaskets to get this clearence. I took one off of my SMTA a while back and the drive gear and shaft would move around in the body, shaft was worn badly on the outer end. I bought a used pump from a salvage yard. If you have the engine torn down be sure to check the main and rod bearings for clearence. I'm also told the cam bearings have a good deal to do with keeping oil pressure up.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
