M misses bad in 5th gear, lots of other questons too.. Help!
Posted by Kenny Christopherson on January 01, 2002 at 09:40:55 from (64.12.104.47):
Just got my 1940 M 2 weeks ago. It runs like a clock, and tin is straighter than an arrow. When I put it in high gear and go for about a half a mile, it runs fine, But after that it starts to miss, it doesn't happen on hills, just level ground. Any idea what it could be? In all the other gears, it is fine. I have never done points/condensor or anything on a tractor. I am not very good with electirics. The dealership I got it from said he just gave it a tune up, and a new battery, which I am haveing doubts about the new battery.It LOOKS new, but sure doesn't perform like it. I know the on/off switch needs some cleaning, because you have to pull with all your might to get it all the way out, but that is not the problem with the battery I don't think. This tractor is posotive ground, and I am not sure if it is a 6 volt or 12 volt. The battery has the 3 caps for the acid level, the acid is over the fins in the battery, so that can't be the problem. We have to keep jumping it with the truck. The symptoms are as follows: With switch all the way out, it cranks slow, then once you crank it again, it cranks a little faster, but not quite fast enough to pop it over. Then it starts to get slow again. It started fine a couple weeks ago when it was 40 degrees, but now its about three degrees, and it doesn't crank much at all. I am thinking it is the cold weather, and it just wore the battery down, but I could be wrong. This tractor does have a block heater, and I do plug it in when I want to run it. It takes a while for it to get it up to operating temp. I was looking at the tractor-with the hood and grille off for cleaning, and I found a plug for an extension cord or something that goes down into a cylinder head stud right behind the manifold, alongside the valve cover. It comes straight up out of the top of the stud. I haven't plugged it in yet, as I don't want to ruin anything. Any idea what this little plug is for? Anyone ever had any luck with getting that hand crank mechanism to turn? Mine is rusted solid. The part that the hand crank connects to moves, but once it makes contact with the piece inside the front bolster, it stops. I know this post jumps around a lot, but I would rather put out one long post instead of 4! Thanks a lot to all who replies! HAPPY NEW YEAR!
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
