Farmall Tractors Discussion Board
Re: Super C Battery Backwards?
Posted by Curt Cooke on March 15, 1999 at 05:51:11:
In Reply to: Super C Battery Backwards? posted by Bill H on March 14, 1999 at 19:32:10:
Hopefully you'll get some responses from smarter people than me but here goes. The starter will work fine with the ground either way, 6 Volts, 8 Volts, 12 Volts - it doesn't care. You won't burn anything up by correcting the polarity. Quick check? Get your battery turned around, make a light work so that when you turn on the switch there's a draw, observe the amp gauge, it should show discharge. This test will tell you if the wiring in the dash is correct. Polarize the generator, check to see that the wire connected to the Bat terminal on regulator is live, run the tractor, observe the amp gauge. If there is no charge, open the cover on the regulator (cut-out)and phsically close the contacts, observe the amp gauge. If all has failed so far, attach a lead wire from the F terminal on generator to the ground strap of the battery, observe the gauge. Again physically close those contacts. If at this point the contacts do not stay closed and no amps are registered and the wiring is right, the generater is a goner.
Post a Followup
: Re: Re: Super C Battery Backwards?
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
