Re: Front wheel shimmy - SMTA
Posted by john d on January 07, 2002 at 18:15:35 from (64.12.106.26):
In Reply to: Front wheel shimmy - SMTA posted by Tom Fanning on January 07, 2002 at 14:01:33:
Before you start replacing bushing in that front pedestal, check for all the simple fixes first! If the universal joint replacement helped a lot, the pedestal bushings may not be a big part of the problem. Accumulated movement in several places may be the most of the cause. Do as Red suggests and jack up the front for a check, and while you're at it, run first one front tire, then the other up on a 4" block and shake the wheel that's in mid-air. Bad wheel bearings can be a source of this trouble. You mention that the tractor has power steering. One of the first casualties of the steering system on old Farmalls, particularly with power steering, is the little ball bearing at the top front side of the gearbox on the front steering pedestal. It's easy to replace, and pretty inexpensive. If it's bad, you'll have problems no matter what else you fix! If the gearbox on the upper end of the pedestal is out of lubricant, then the possibility of bad pedestal bushings increases pretty fast. If the gear lube is gone, plan on putting in new gears! Next to the universal you replaced is a support bearing. It's a rather anemic part, compared to the rest of the tractor. If that support bearing wasn't greased regularly through the life of the tractor, it may be part of the problem. There are two common types of power steering on these old tractors. The Behlen type has a big actuator unit over the gas tank. They're ugly, but they work well. I've got a 52 SM with one of those on it, and I had to fabricate a couple of braces that run from the light bar to the channel frames at the rear of the engine to brace the steering wheel pedestal so it wouldn't shake around under some conditions. The front wheels on mine didn't shimmy, but the steering wheel wouldn't hold still, and caused the front end to "wander" somewhat. If you end up replacing the front pedestal bushings, be absolutely certain the tractor is blocked up well and the brakes are set so it can't move - ANY! Good luck!
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
