Re: Valve cover gaskets
Posted by Haas on January 08, 2002 at 06:03:43 from (129.37.117.52):
In Reply to: Valve cover gaskets posted by Craig Goth on January 07, 2002 at 22:10:30:
The leak is easy to fix. Get a new gasket from a Case/IH dealer. Then remove the cover and clean the surfaces good with a flat scrapper blade to remove all the old gasket material. Get a tube of Permatex red silicone gasket sealer at an auto parts store. Lay a small bead of silicone on the metal surface of the head and seat the gasket. Then put another small coating of silicone on top of the gasket and put the cover back. Let sit for a few hours to let the silicone harden. Use just enough silicone to make the gasket stick. You don't want silcone to extrude out into the valve area or out the sides. And...while you have the cover off, it's a good time to check your valve rocker arm clearances and the push rods to make sure all is OK there.
Post A Followup
: Re: Re: Valve cover gaskets
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
