Farmall Tractors Discussion Board
Re: Super C starting
Posted by Phil Auten on March 16, 1999 at 18:31:10:
In Reply to: Super C starting posted by Frank Zanaboni on March 16, 1999 at 06:17:10:
Frank,
Some good advice from Steve, Red and Curt.
Check the connections first. Replace the battery
cables next and use the largest wire you can find.
(#0 wire would be better than #1)
Take the Generator to a Starter/Generator/ Alternator
shop that has good references from
folks you know and have them give it a load test.
I had an alternator that looked ok until it was
loaded and THEN it failed.
Have the starter tested the same way. Rebuild
them if they need it (far cheaper than replacing).
Check the switch. We went through this a while
back with someone else on this list on an H and
the switch was the culprit (bad contacts). Even
the slightest resistance will drop a couple of
volts at over 100 amps. If you have a voltmeter
and understand how to use it you can figure this
out easily. If you don't, make friends with
someone that does and ask them to help. Keep us
posted here, there are lots of guys on this board
that have done this type of thing more times than
they care to remember. Someone out there knows
the answer!
Phil
Post a Followup
: Re: Re: Super C starting
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
