Farmall Tractors Discussion Board
300U Info
Posted by Tim on March 19, 1999 at 05:23:49:
I'm going to check out a 300U with loader this afternoon. I've already learned from this board that the TA and front steering can be problems, but I have a few further questions. How do I check the TA? Just make sure it engages and doesn't pop out, or is there more to it? Owner says he changed the hydraulic pump and still has problems. Thinks its a control valve. Sound right? Also, the previous owner disconnected the power steering when the pump was bad. If the steering is tight without power, will it be OK with power? Are there any other flaws I should look for? Thanks in advance for the help.
Post a Followup
: Re: 300U Info
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
