Farmall Tractors Discussion Board |
Re: Re: Re: Stuck Sleeve with PIX on 51 H
Posted by John C. on March 19, 1999 at 06:25:40:
In Reply to: Re: Re: Stuck Sleeve with PIX on 51 H posted by The Red on March 19, 1999 at 04:43:34:
If you can warm up (heat up) the entire block assembly and quickly load up the sleeve with dry ice, you might get the sleeve to shrink enough to pop out. The block is very massive compared to the sleeve, so if you can chill the sleeve very sharply (?), you can get it to shrink before the hole in the block shrinks also. I've heard of farmers chilling new sleeves by leaving them in their original box and shooting propane into the box. Propane and Carbon Dioxide (dry ice) both have very cold boiling points, so their effects should be similar. I hope some or all of this trivia helps.
Post a Followup
