Farmall Tractors Discussion Board
Re: cracked head??
Posted by Phil Auten on March 19, 1999 at 17:48:15:
In Reply to: cracked head?? posted by Sly on March 19, 1999 at 15:53:46:
Sly,
With the tractor running, remove the radiator cap and check for bubbles in the coolant. This will indicate a leak between combustion pressure areas and the water jacket. Could be a cracked head, a bad head gasket, cracked sleeve or something worse. The only way to tell for sure is to have the head "Magnafluxed" by a shop. This will tell you for sure if the head is bad. Even the tiniest crack will show up in the Magnaflux process.
Good luck,
Phil
Post a Followup
: Re: Re: cracked head??
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
