Farmall Tractors Discussion Board
50 H... what is this cable for???
Posted by Grant on March 30, 1999 at 10:09:25:
I'm restoring a 50 H ... rebuilt engine, including new pistons and sleeves, new this, new that ... you know the rest. This tractor was not running when I got it, and I've never seen what I'm going to inquire about on another H thus, this question.
There is a jacketed cable, like a choke cable, that is bolted to a bracket and attached to the arm that holds the belt pully rod. It has a large knob type handle, round like a shift knob. The other end enders the 'intermediate' case, on the right side of the tractor, in front of the hydralic ports. It passes through a hole that is bored through the case. If you remove the belt pully assembly, you can look inside and see the other end attached to some sort of slide, probably a valve, that goes what looks like into the trans case. It doesn't look like a cobbled job. Any ideas what it is? Obviously, the tractor is not running yet, but as soon as I run out of old parts to replace with new, I'll have her! Thanks, Grant
Post a Followup
: Re: 50 H... what is this cable for???
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
