Farmall Tractors Discussion Board
51 Farmall H came to life but running more like a Dang Ol Deere.
Posted by The Red, John Fritz on April 02, 1999 at 14:55:48:
After 2 long days I finally gave it a fire at 4:30. It started popping almost immediately. Open up the mix and then she came to life. Since I had worked some oil on the top of the pistons, she smoked for about 5 minutes then it cleared out. Oil pressure went right to 60 psi.
She only ran on 3 for a while and now on 4 but not smooth. I pulled each plug wire and all 4 plugs are working fine. I found the sweet spot on the timing and was only 10 degrees off or so.
She's running on 4 but sounds like 3 1/2. Its noisy under the valve cover so I suspect one of my clearances got loose.
Governor is not responding steadily. Prob. weak springs.
Gas bowl is leaking badly. Someone rigged in a cork gasket. My fault for not catching that.
So I suspect it will take a couple of more hours to work out the bugs and hopefully that #1 sleeve will settle down.
At least she is running a WHOLE LOT BETTER than before I tore it down.
That is it for now. I are tired. 14 hours yesterday and 9 today.
Post a Followup
: Re: 51 Farmall H came to life but running more like a Dang Ol Deere.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
