Farmall Tractors Discussion Board
What Have I Got Here ??
Posted by Eddie Petty, Courtland, Va. on April 04, 1999 at 12:28:09:
I was rummaging thru a deceased farmer friends' out buildings yesterday when I uncovered a IH power unit. The engine is the typical in-line four cylinder EXACTLY like the engines in my '44 A and '44 B. Attached to the clutch housing is what appears to be a speed decreaser. The unit has a self contained radiator and fan assembly again very similar to the A and B. The bellhousing is quite short and the clutch is operated by a manual lever on the right side. The unit has an attached gas tank of approximately five gallons. The starter (which is missing) mounted to the front of the flywheel (unlike the A and B). The air breather is exceptionally tall and has a very fine screen mesh surronding the entire assembly. There are cast feet, two under the clutch housing and two under the radiator support. Provisions are also provided for a hand crank. The oil pan is flat bottomed and the block actually has a dip stick instead of the hi-lo oil cocks that I'm familiar with. The block serial number is MAM G and below that is 8822. The block casting date is 7*2*X.
Okay folks, what is it,how was it used and when was it built.
Post a Followup
: Re: What Have I Got Here ??
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
