Farmall Tractors Discussion Board
12v alternator hook-up question H
Posted by RK Smith on April 05, 1999 at 20:14:04:
bought an H (1941) few weeks ago, runs super - haven't done anything to it related to my problem: problem is the prior owner had "just converted to 12v alternator," and I didn't get a chance to ask him if he had noticed any problem. But, the tractor won't charge the battery. It won't charge regardless of how long I operate the engine, or at what speed, and the belt connection is fine. Took the alternator to AutoZone - checks out super, good as new. I am unfamiliar with "positive ground systems, and my H is positive grounded," so question is - "How do you hook up the alternator?" Specifically - where does the line from the "stator" run, and where does the line for the "field" run? It was hooked up with the stator line to the pos term of the battery and the field line to the ignition switch, which doesn't seem right to me because I believe the polarity of this alternator is for the diode to produce a "+" charge, and the frame of the alternator is common with the chassis, which is pos grounded to the battery. The AutoZone guy says the alternator is just grounding all the output for nothing. Starter is pos grounded and hot line from the battery runs through the starter relay switch. Please, I need someone who knows dead on. Thanks, RK Smith
Post a Followup
: Re: 12v alternator hook-up question H
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
