Re: voltmeter setup
Posted by charles todd on March 17, 2009 at 21:39:27 from (205.242.95.137):
In Reply to: voltmeter setup posted by JeremyG on March 17, 2009 at 20:31:28:
With a voltmeter you hook the positive to the ignition coil switched hot and the negative to ground (with a negative ground system). The reason for this is so when you shut off the key it turns off the voltmeter. If you do not have a key, like on a mag system, I suppose you could run it through an oil pressure switch. As for the "other wire" it is probably for a light bulb. It will be obvious if it has a light, it will be a wire out the center of the voltmeter. Wire the light to the headlights or dashlights.
Good luck,
Charles
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
