Farmall Tractors Discussion Board
Re: M oil pump and cam removal
Posted by C.Fitz on April 06, 1999 at 23:33:36:
In Reply to: M oil pump and cam removal posted by Gary Sayre on April 05, 1999 at 16:36:39:
The oil pump has to be taken off first by the 2 mounting bolts and it should pull down as it unmeshes with the cam-shaft gear. To get the camshaft out you have to take off the front timing cover, which involves a whole lot of work. the radiator needs tocome off, the front crankshaft pulley needs off. Then unbolt front timing cover.You'll also need to pull rocker arm ass.; pull lifters out, then take that tappet plate off the side of the block and lift your tappets out from off the cam-shaft. Then you can unbolt the cam-shaft timing gear bolts and the cam-shaft should pull out with the gear attached toward the front of the tractor. I might of forgot a few things but that should get you in the ball-park. Have fun.
Post a Followup
: Re: Re: M oil pump and cam removal
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
