Farmall Tractors Discussion Board
ATTENTION: all you 6V - 12V converters
Posted by RK Smith on April 11, 1999 at 12:47:37:
You may appreciate me for this later so write it down. If you end of converting using an alternator that is "not internally regulated," then you will need a voltage regulator. I've just done this and this one is super: Contact YT and see if they can cross reference AutoZone part number 129965 and also reference VR706. This is an "electronic two wire voltage regulator" that was used on pre-1970 chrysler products. It is small, easy to bolt to the chassis, and has one terminal marked "field" for the line from the "field" to the voltage regulator and one marked "ign" for connecting to switched positive battery voltage (run it to the "dead" side of the switch, so that it is live when the switch is on). Note: this is only for neg ground alternators, and therefore your tractor has to be converted to neg ground. If YT can't help, go to AutoZone - it isn't expensive. enjoy - RKS
Post a Followup
: Re: ATTENTION: all you 6V - 12V converters
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
