If you are not getting poor quality rebuilt alternators, or have high electrical demand due to added accessories, the most likely problem is faulty wiring. Excess voltage will cause failure due to over heating. Those alternators will fail if run at maximum output for too long a period of time.
A poor connection can cause the regulator to demand maximum output from the alternator. Inspect the main wire from the solenoid battery post to the alternator output stud. Make sure that you do not have a poor connection between the connector and the wire. If that wire is good you should be boiling the batteries if the voltage is too high. Inspect the junction block and the wires going from the solenoid to the junction block, to the regulator. A poor connection there can cause low voltage at the regulator which again will cause the regulator to demand higher voltage.
With the system working you should not see more that 15 volts at the alternator output terminal, usually less than 14.5 volts. You should have no more than .1 volt drop across any connection. If you have .5 volt difference from the alternator output to the battery terminal on the regulator you are going to have problems.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
