Farmall Tractors Discussion Board
Re: Cub no Spark
Posted by RK Smith on April 18, 1999 at 04:24:18:
In Reply to: Cub no Spark posted by rich Miller on April 17, 1999 at 23:45:33:
don't know if you have mag or distributor, but 1st suspect in both is the point set. Then the coil if you have a distributor. You say it finally runs, so it finally gets spark "somewhere," and a coil is a mystery with gremlins inside. Substitute the coil temporarily and see if it cures the problem. Also, are you able to check the factory specs for timing? and timing advance? If so, tell me what you did, and what you set things on? Which cylinder? Where did you set the mark? What's the advance? What rpm for both? If this is all greek, you can have no confidence that the ignition is right. It has to be close enough to right, or you'll never get it running and cranking right by just looking at the plugs, wires, and looking for spark.
Post a Followup
: Re: Re: Cub no Spark
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
