Farmall Tractors Discussion Board
Bolster Shaft End Play - Farmall H
Posted by john on April 20, 1999 at 08:58:55:
I am rebuilding the front end of my H tractor and have put in new bushings, brgs, seals, all the way around. Now that the new parts are in I am noticing at least 1/8" up/down movement of the bolster steering shaft. Does anyone know what the spec should be for this?? And, if shims are necessary should I split the difference between the thrust brg and the sector gear?? Thanks.
Post a Followup
: Re: Bolster Shaft End Play - Farmall H
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
