Re: IH 574 with Allied loader - hydraulics
Posted by Fromjb2 on February 20, 2007 at 20:00:33 from (74.101.67.211):
In Reply to: IH 574 with Allied loader - hydraulics posted by father-in-law's nightmare on February 19, 2007 at 18:38:56:
Hi, since brakes and PS work good then the problem is not the hydraulic pump as the first thing that goes is the brakes. If the loader arms drift upward then possibility a problem with with the external hydraulic control valves. Slow response time could be a flow problem anywhere from the MCV valve to the loader cylinders. The usual way the external loader hydraulic control valves are connected into the tractor hydraulic system is by removing the hydraulic return pipe off the top of the remote outlet control valve by your right hand under the seat. The return pipe goes from the remote control valve to the draft control mechanism under the back of the seat. This pipe is removed and the inlet side of the external loader valves is connected to the outlet at the remote control valve and the outlet of the loader valves can be returned to the inlet of the draft control mechanism or the draft control inlet can be capped off and the outlet of the external loader valves connected to a drain plug by the bottom of the right axle or filler plug behind the seat. Since this is an open center hydraulic system oil has to constantly flow in a loop unless it is diverted by a valve. So if you use the remote control lever by your right foot to operate a remote cylinder the loader will not work as there is no oil flow to the loader control valves. Hope my explanation of the hydraulic setup will assist you with trouble shooting the problem. Can you switch the control valves between loader arms and bucket to see if symptoms change? Good luck JimB
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
