Re: How am I going to get these wheels off?
Posted by Janicholson on February 23, 2007 at 06:26:56 from (199.17.6.122):
In Reply to: How am I going to get these wheels off? posted by Mike CA on February 22, 2007 at 23:46:59:
Richard in NZ has the ticket. As he indicates, loosen (or twist off) the lugnuts on both wheels (not much, but to get them broken loose). Jack up the tractor, and block under the axle housing on each side so that the tires are just barely off the ground. Then remove the lug bolts. Be careful with the tires, they may be full of liquid. They may weigh 1000# each and can kill you. A good professional level ton and a half cherry picker is definately needed (rental is OK). When the tires (which have a standard pattern to the bolts, and can be sold on Ebay easily) are out of the way, use an angle grinder with a cutoff wheel to grind through the hub along the keyway. This will take several hours, and many sparks, and old cloths, and dirt, and a mask, and gogles. When cut through, wedge the crack apart with chisels to open the hole, and slide them off. If you want to go faster, have someone with a portable cutting torch (who knows how to use it) come over and cut the off. THis is best done outside due to the far hotter sparks and serious hot metal. Getting them off by force is possible with a heavy gear puller and some heat. Sanding and polishing the outer end of the axle, and using a porta power would also work. Good luck, it is possible, but a serious task. I do not believe they are welded at the axle on either side. JimN
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
