Re: 966 Questions
Posted by Sheepdog in NE on February 25, 2007 at 18:00:30 from (67.0.15.130):
In Reply to: 966 Questions posted by GEJD60 on February 24, 2007 at 18:37:08:
The spring he speaks of is under the range cover that is under your feet as you sit in the bad seat. There is a floor board plate that comes off with four bolts. Then the cover will have 2 linkage arms going to it from the front and a park brake rod also. When you get all the rods and bolts off of the cover put a nut under the park brake arm to keep it disengaged as you pull the cover up. The cover will be stuck so tap on it with bfh. It's got dowel pins so it won't move sideways. The covers hole sometimes is wore. Get a rebuilt cover and shaft. Under the cover is a cam, spring, roller and another arm. Good luck.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
