Re: 460 IPTO
Posted by D Slater on March 19, 2009 at 15:07:18 from (72.65.149.238):
In Reply to: 460 IPTO posted by Torment on March 19, 2009 at 10:56:28:
Shaft from main clutch to T/A clutch doesn't need lube. If you mean the pto drive gear shaft with the bearings on each end that the main clutch shaft passes through, the cheapest thing to do is remove the rivits and drive lug from pressure plate. None of the pto shafts will turn then. You can remove other pto parts if wanted but the pto drive shaft and seals needs to stay in to keep oil from both clutches unless other changes are made.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
