Farmall Tractors Discussion Board
I the Red, now have De-Danged the 51 Farmll H. RUNNING GREAT!!!
Posted by The Dang Ol Red, John Fritz on April 24, 1999 at 10:54:28:
I spent the whole morning taking my time on the head and the valves. All the headbolts around #2 and #3 had loosened up a tad but not much. The two center bolts between #1-2 and #3-4 were somewhat loose. The front and back bolts were on the nose.
Now on the valve clearances. #1 exhaust was not closing. Clearances on #2 and #3 were way too loose. #4 was fairly close but a little loose. This time after the intake valve closed on #1/4 with the starter, I then turned the engine with the crank until the mark was on TDC. Same thing on #2/3 except turning the mark to the bottom by hand. I did this 6 times. Finally the last 2 times on each cylinder the gaps were at .20 on the nose. I think I was passing by full compression when I was setting them at hour 2.
Going to buy 2 carbs for $80 and get an IH kit. I figure between the 3 I will get a good carb.
I need a spring set for the distributor but it isn't that far off.
I am much relieved that this H is finally behaving.
Post a Followup
: Re: I the Red, now have De-Danged the 51 Farmll H. RUNNING GREAT!!!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
