140 Alternator (conv) wiring: What's wrong??
Posted by Nawlens Gator on March 04, 2007 at 18:56:52 from (74.230.194.69):
Finally mounted a Delco 10 SI on one of my 140's in place of the old generator (12 v neg grnd) and attempted the 3 wire set up per Hal. Also installed a new ignition switch (4 position--> ACC, Off, On, Start [spring]). The four connections to the key switch are labeled 1) Ignition (hooked this to the coil) 2) ACC (hooked this to the fuse then light switch) 3) Bat (hooked this to the alternator, R/1 terminal) this alternator terminal is on the left side when looking from the rear as in Hal's pic and I installed the diode in this wire with white stripe toward the alternator. 4) Start (hooked this to the magnetic relay of the starter switch). Then I hooked the battery up and turned the switch and nothing happened. No current to the start switch when I turned the key to the crank position or 4) (spring). I figured the battery terminal on the start switch must really mean battery after all. So I disconnected the alternator wire (with diode, from the R alt term) and connected it to the ignition position ( 1) ) on the switch along with the wire to the coil. I also jumered a wire from the battery side of the Amp Meter to the Bat terminal of the ignition switch. No here's what's really weird. When I turned the switch to on, the starter relay kicked in and the tractor started cranking!!?? On the bench, this switch in the 'on' position had continuity between the battery switch terminal ( 3) ), ignition switch terminal ( 1) ), and ACC terminal ( 2) ). There was NO continuity to the start terminal ( 4) ) on the switch. I am bamboozold. Do I need a 3 position switch? What the heck is going on?
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
