Re: REMOVING GREASE AND GASKETS
Posted by L Mack on March 12, 2007 at 19:35:22 from (68.157.139.93):
In Reply to: REMOVING GREASE AND GASKETS posted by RICK IN VERMONT on March 12, 2007 at 16:27:14:
Some gaskets may be out of production. If so silicon jel can be used in cases where heat is not a problem. Before you apply silicon you must completely clean the grease with a scraper and a brush (on a drill motor if possible). After all visible grease and gasket adhesive have been removed, wash with Acetone on a rag. Completely clean and allow to dry. Silicon works when both surfaces are solid, not tin. A piece of cut gasket may work best if one side is tin. Use aftermarket gaskets if you can get them. (For those that are skeptics, Silicon Jell was the gasket of choice for truck rear axel ends. Break jobs on trucks require that the rear axels be pulled in many cases. We learned that paper gaskets would simply squirt out and leak in use. I was told by an old experienced truck mechanic to use the silicon and leave off the paper gasket. It worked and never failed.)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
