Re: 504 rough running, distributor/timing??
Posted by Roger Mills on March 17, 2007 at 06:45:34 from (71.213.68.215):
In Reply to: 504 rough running, distributor/timing?? posted by RUSTY in TX on March 17, 2007 at 01:09:03:
You could have the drive gear off one tooth. Find #1 compression (finger in the plug hole trick) then line up tdc and the rotor should point to #1 and points should just be opening. If so you are close. Rough idle could be mixture and same for high end--check carb and fuel flow, might be starving at high RPM.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
