Re: Farmall M tranny, ring and pinion
Posted by D Slater on March 20, 2007 at 18:12:43 from (152.163.100.5):
In Reply to: Farmall M tranny, ring and pinion posted by firefarm on March 20, 2007 at 11:22:30:
Farmall M and W6 main shaft 19 teeth,not same shaft though. Farmall M ring gear 50 teeth, W6 47 teeth. Third gear M 26 and 37 teeth, W6 27 and 36 teeth. As you can see third could be speeded a little with W6 gears but to change you have to go with 3&4 drive gear,2&3 slider and 4th slider from W6 and that will speed 4th up also. I wouldn't be using 4th in a high horsepower M because its the weakest gear. W6 ring and main or pinion shaft will speed all up.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
