Put a amp meter on the system (if it has an amp meter working in the switch box, use it) Turn on the ignition and watch the amp gauge with it stopped. It should show 2 to 3.5 amps draw. If it is more like 6 or 7 amps, I would use a good hand held amp meter (Multi-Meter set to amps, not Milliamps) as follows. Take off the wire on the side of the distributor. Put one ;ead om the distributor post, and one on the wire end you removed. Turn on the ignition (not started) It should read about 3.5 amps or less. More means the coil is not right. (a super hot coil might do this, or a bad coil (even new)). If it is in spec, I suspect oil or grease getting on the points. JimN
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
