Re: clutch surprise/oops
Posted by Owen Aaland on March 23, 2007 at 16:44:02 from (65.165.246.14):
In Reply to: clutch surprise/oops posted by karl f on March 23, 2007 at 16:27:07:
I assume you are talking about the main clutch. If not, the same principles apply to the TA clutch. Remove the bottom inspection cover and inspect the clucth pressure plate release levers and make sure they are not burned on the tips. The levers should all be equal distance from the release bearing. The levers should be close to parallel with the flywheel. Also reach up and feel the release bearing. Make sure that the balls have not fallen out of the bearing. Inspect the release fork to see that it is tight on the clutch shaft and has not moved. Check the weld on the outside of the clutch shaft arm to be sure that it has not broken and turned on the shaft. If you find nothing wrong, then you are probably right that it just took this long to seat itself correctly.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
