Head gasket and other surprises
Posted by Roger Mills on March 25, 2007 at 08:24:50 from (71.37.118.105):
Last week I posted about taking an A to its (our) first show. Came home with lots to do on a tractor that was supposedly restored. First, head gasket was leaking oil so I pulled the head. I put a torque wrench on one of the nuts to check it and found that it was only about 25-30 ft/lbs so no wonder it leaked. When I got the head off I could still read where the gasket said "Sealer/retorque required"--no sealer either. What I did find was pop up pistons and new sleeves that all had the 'B' codes stamped on them--matched set. Also found new valves, springs etc. AND the offset rockers for valve rotation. At least now I know why it turned over so slow with the 6 volt starter. Second, I decided that since I would have the whole front off I would add a water pump. More to stabilize the running temp than any other reason. I found one at Ag Ind products for $70 that said A,B series and had the wide belt pully already on it. Cheap enough but won't work-center hub of pulley and shaft stick out too far for the fan to clear. I could take the pump down to a shop and have the extra cut off but I don't know if there would be enough 'meat' left to keep the pully from spinning on the shaft, it looks pressed on. So, where can I get one that will clear the fan, or do you think the cut off idea will work???
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
