Re: Front wheel seals
Posted by CNKS on March 25, 2007 at 16:41:31 from (204.249.178.32):
In Reply to: Front wheel seals posted by VAJerry on March 25, 2007 at 11:46:54:
Not sure of the Super A, as the different models are not exactly the same. Basically all you need to replace, unless wear is severe, is the dust seal, sometimes called an oil seal (see below), and the bearings, if worn excessively. The cups the bearings run in are replacable in case of excess wear. I have not replaced the bearing cups, but have replaced the cups the oil seals run in. Those seals just keep dirt, etc out of the bearing, and if the tractor sees little use can probably be ignored, but I don't like to leave out parts.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
