Re: Different crank seal question
Posted by CSR on March 27, 2007 at 03:41:23 from (192.249.47.8):
In Reply to: Different crank seal question posted by Roger Mills on March 26, 2007 at 15:30:23:
You have to remove the timing cover because the seal goes in from the rear. I just started all the bolts, figured I'd finish running them in after the pulley was installed and concentric with the crank seal, but I couldn't shift the cover around before I installed so the pulley, so I just tightened the cover. My pulley ID measured about .002 smaller than the crank. I gave it a light flapper wheel, then heated the pulley to 300F for 3 hours. At 1.25 in diameter (going from memory), a change in steel temperature of 230F (300F-70F) will change the diameter .0018 which reduced the interference fit from .002 Tight to .0002 Tight. A light tap with a block of wood and a hammer and it slid right on. I then started cooling the pulley immediately by wrapping a water soaked rag around it (next to the seal) till the rag smoked, then I'd resoak and do it again. I lubed the crank up good with oil before I started and made sure I put some camshaft assy lube on the seal also. Most silicone rubber products are advertised as good to 500F so I felt 300F was OK, plus the wet rag pulled the heat from the pulley rather than have it heat soak the seal.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
